HI,
I must confess, you worry me. You are doing nothing but guessing. Resistors such as the one in the photo, are rarely the primary cause of a problem. Rather, they reflect another problem. Something caused an over current condition that caused that resistor to burn. Replace it and it will burn again unless you find the original problem. It may also cause additional problems. Yes, it could be a capacitor but it could be many other things as well. Without a schematic in front of me, I can't really guess.
If you replace the 1/4W with a 1/2 W, it will work fine (it you have room for it) unless the original problem is still there. In that case the 1/2W resistor will still burn but burn hotter and cause more physical board damage.
If you had the experience and knowledge (which you clearly don't) I'm sure you would find a simple problem like a bad transistor or a bad capacitor. When I say find I mean find by real troubleshooting and understanding of the circuit rather that the shotgun approch you are using. I don't like what you are doing because you may well cause further and more serious problems.
I suggest you get this turntable to a professional for repair before you make a real mess.
Sorry to be so stark but having run a professional repair shop for many years, I have seen this happen many times. I always attribute it to stupidity. Don't you be stupid. You are on the brink or maybe even over the brink.
Sparky
Sparky
