Revox Stopped working
Hi Pio1980
I saw your post #7. You correctly indicated that C1 could be a problem. MY QUESTION was whether it had ever been replaced - I just know from personal experience that it is a highly stressed part.
I'll retire from this post, I wish the ReVox the best of luck!
Dale
I've gone through this post's 3 pages and haven't seen that you replaced capacitor C1 (22uF @ 16V) on the Tonearm's PCB. I had the exact same problem where the relay would not open (it's NC) and hence remove the ground "short" to the outputs. The problem turned out to be capacitor C1. If you haven't replaced it then that is the first thing I would do at this stage.
You can also "pop" the plastic cover off the relay and with a small piece of folded paper/cardboard force the relay's contacts open and hence effectively remove it from the circuit - this way you won't risk PCB damage by trying to unsolder it. If you use a small enough paper wedge, you can also replace the relay's plastic cap and forget the relay completely.
Dale
Hi your right I missed replacing C1 I did however try a paper shim with no luck, I will replace C1 and get back on this ASAP, Right now I have the grado cart off the revox playing on my Mitsu TT. But I have a shure V15 IV I can throw on it to test with, Cart setup on these is a PITA.
I replaced those gold FRAKO caps with no luck and Ive been on another project for a bit. Here are some pictures of the boards with the new caps to date.
The relay is not working. According to my service manual transistor Q3 controls the muting relay. Either the relay is bad or something else in the circuit is not allowing the relay to work. Remove the leads from the cartridge, check both RCA plugs for resistance with the arm up and down. If both stay the same with a low resistance, than the problem is not from the arm control board to the cartridge. Beyond that I would PM steerpike2 to see if he can offer any help. He is real good at troubleshooting these tables.:thmbsp:
Thanks for giving me a holler. and for your advice.
Well I finally got the Revox back up and running today and Im giving it a good run with the new caps and the grado cart, so far its sounding really good, I dont know if the new caps effect performance but Im glad to have it back up playing again. ( C-1 cap fixed the muting problem) Also some others needed replaced so I replaced all of them.
Special thanks to all the members who posted on this thread and helped me get her going. Here is a pic of the 790 today.
It's a fair bet that your turntable is performing the best it has performed in a long time--although things can (usually) get pretty bad before they stop working.
That is one crazy looking tone arm assembly! How do you get the record out from underneath it?
Some pics with the cover off, with the arm in the play and stop position.
There are switches on the arm for the return and also for stop once it returns.
Pretty much Auto everything. Its a very easy table to use as long as everything is working. :D
Excellent, Enjoy!:music:
I have a Signet MK110E MC cart that I think was on this table back in the day, but it needs a stylus. Do you think the revox would sound good with a MC cart like the Signet. Im a little concerned about putting money into the signet, but I want to really see how good I can get the 790 sounding this time around.
Any Ideas ?
Any Ideas ?
I honestly don't know, that would need some input from others. Keep in mind that most cart 'families' have a 'house' sound and that will have a bearing on one's personal preferences. Given what a PITA this is to set up I'd nonetheless go with a recommended cart with an easily user-replacable stylus (definitely NOT a Grado!). An Ortofon OM-20 or 30 may please F.I.
Thanks, There doesnt seem to be a whole lot of info from users about the Signet but considering the price of the stylus I would say it was expensive in its day. What little info I got here suggest its similar to the AT30 or AT31 but with slightly higher specs. The stylus seems easy to change.
I emailed the original owner and he said he had TOTL cart on it that got (gone) while it was in storage, I didnt ask what brand, but if the signet was a sub it was probably a very good one.
Ive never heard an Ortofon but I have read some good things about them.
I am also considering getting another jico stylus for my Shure V15 type IV,,,, the prices on those have gone up a bit lately
If you like the Shure, remount it and get the JICO. It's not stressful to the arm to properly change that stylus and the stabilizer brush is a bonus for you. Besides, it's already paid for.
If what Im reading is true, some MC carts dont do well with really light arms such as I would think the revox arm would be considered very light (im just guessing here) but it does make me wonder.
Your right I already have the Shure, it was free as is most of my gear except for the cost of restoring 30 yrs of neglect so I will probably go that route.
I would however like to try a MC cart on one of my tables,,, that would let me use both inputs on my Mitsu M-P01 pre-amp and I could keep both tables hooked up and switch back and forth easily without having to move everything.
My other table is the Mitsubishi DP-EC20 (Diatone EC-1 MKII) I have no idea if its compatible with a MC cart.
I have a Shure V15 IV with a JICO stylus on my B790. It is my main table and has the most neutral clear sound of any cartridge I have ever used. I have been through many in the last 45 years!:D
