Pioneer thought it would be a fantastic idea to wire-wrap the transformer to the PCB. So, unfortunately, my only choice here is to undo the wire-wraps in order to remove the PCB. The problem is that the brittle 37 year old wire is now not long enough for me to create a new wire-wrap connection, let alone solder them, so I think I'll just replace the wires. What I have as a replacement is 20 AWG single insulated wire, rated at 300v and 105c. It's pretty much the same as the factory wire, both being 20 AWG, though I can't find a voltage reading on the factory wire. And the factory wire is double insulated and noticeably thicker than the new wire. Would this pose any problems, such as a noisy circuit?
