Room EQ Wizard (REW) Questions for Testing Vintage Audio
So I've picked up a pair of Minimus 7W speakers on the cheap. Initially I was pretty impressed for how well they sound, but I got the sense that there wasn't a whole lot going on by way of a crossover. Opening them up I found that there is only a single cap and figured that I could do better by adding a appropriate crossover. I would like to do a little testing and after doing a little bit of research I found that Room EQ Wizard (REW) is just what I'm looking for--Extra points to REW for being supported by Linux! Ultimately my plan is to test the speakers: 1st with a replaced capacitor (4.7uf/250v), 2nd with cheap commercial x-overs, and 3rd with custom-built x-overs down the line. If there is an interest I will post the results in a single thread.
I am still trying to get acquainted with the software interface and was wondering if there are others out there who might be able to advise me on a couple of things. My overall goal is to create a small vintage speaker and amp setup that I can use with my desktop computer. I have settled on a pair of Realistic Minimus 7W speakers and a Pioneer SA-7100 amp. I built my own simple mic using a small surface-mount package which can measure somewhere within the range of 20 to 25kHz--no, I can't calibrate it, but it's cheap and I hope will get me within the ballpark of what I am trying to do. I have a number of questions as I'm quite new to this:
1) Is there a way to calibrate my soundcard via the SA-7100 amp I'm using? I'm thinking of maybe creating a loop via Aux (in) and tape (out). Am I on the right track here?
2) At what distance should I set the mic? Should I place the speakers where they will live on my desk and take the measurement from the approximate space of where my head is to be situated?
3) Should I meter each speaker independently or both together?
4) Where should I put my level adjustments on my amplifier? For testing purposes, is it best to set everything at their default zeroed positions, maxed out, or at the settings I will likely use for listening purposes?
5) Is there any way for REW to crop out or account for the reflections created by the small space of my office?
6) Any other bits of advice?
Many thanks for all the help and input that is offered here on AK.
Save yourself the headache and go to Zilch's legendary thread about the Minimus 7. The late Zilch took those things about as far as possible.
I know that's not what you asked for, but you ought to give it a look anyway. Best of luck.
Yeah, I've read the posts that you've linked to before and plan on building a pair of Zilch x-overs. Which x-overs to use isn't a question that I have as I've got that part figured out. What I'm more interested in is learning how to test my own equipment.
I would still like help with properly setting up and using REW for testing the frequency response of my current and future speaker setups.
Hate to redirect, but there is nearly an entire REW forum, or subforum anyway, on another site, yes? There is no rule that you can participate in only one forum. :thumbsup:
I mention it not because some questions can't be answered here, but it sounds like you're looking for a rather complete dissertation on speaker and or room measurement theory and technique. I think that sort of thing may already exist on that other site is the only reason.
I've been led to believe that HT Shack is the home base for all things REW. It's where I first heard about it 7(?) years ago. The exact year doesn't come to mind. However, I've been using it through several updates.
