TellMeWhy
I recently purchased a Rotel RA960BX integrated from the German auction site and it seems to run hot (almost too hot to touch on a 4 ohm load. I've read other reports of this being the norm, but opened it up anyway to have a look.
As you can see, there's obvious heat damage to the plastic casing of the power supply caps and the resistors next to the heat sink. I haven't checked the bias and DC offset yet but I guess that would be a start.
My question is if this cosmetic heat damage may have damaged the components themselves (other than shortening the life of the caps which I realise)? The amp seems to work great, sound is perfect, power is ample for 60w.
Thoughts?
Thoughts?
