budgetaudio6
Addicted Member
ooohh! those are nice. if youre going to glue the broken part see if youcan add something to strengthen it as well.
When I got my 4Bs there was a serious lack of bass. The woofers had been wired out of phase within each speaker. I was ecstatic when I got that straightened out. JK
Hey Rod; Glad to hear you got the wires straightened out. You diagnosed that correctly. I thought for sure it was the crumbling surrounds that had them so bass shy. I'll have to check them out once you get them re-surrounded.
Sorry for getting back so late. Glad an old post could help you out. Yes two woogers out of phase in the same speaker do sound bass shy. Its also not as easy to diagnose as speakers with a single woofer. In that case if you stand in the sweet spot no bass, but move in front of either speakers and have normal bass. I don't understand how this happens. But it could be why there are some deals out there on the 4/4Bs. Re-foam enjoy. And I was JK (just kidding) about the plants.
Bill
P.S. you could also do the battery test and make sure they both travel in the same direction.
These woofers are very easy to refoam because of the poly cone, it is easy to clean off all of the old goo.
I had a bit of a problem because I found a set of four surrounds really cheap...the caveat was they measured too large on the outside perimeter and kept centering off-center. I should have trimmed the surrounds down with some scissors.:yes:
Very interesting reading earlier posts about woofer wiring. I just refoamed my RSIIIb's and was a little confused when reinstalling the drivers. There wasnt any real problem because the wires were "color coded". It seems as though the woofers were designed to be wired out of phase as there was a positive lead wire connected to the bottom woofer's positive terminal. A negative lead wire was connected to the positive terminal of the top woofer. Both upper and lower driver's negative terminals shared a simple common wire. The bass seems fast tight and stong, even out of phase.
Here is my attempt at graphically showing how my IIIb's woofers were wired.... (pos) blue wire______+\__/- common wire -\__/+______ (neg) red/black stripe wire. Maybe this is another form of wiring in series?
No that is a way of wiring them in series out of phase. Unless something really weird happened like a voice coil in wired wrong. they are in series the way you diagram but out of phase. Once again I urge you to use a battery to check phasing. That will be the final test of phasing. If they are out of phase you will be amazed at the bass you get. Trust me that this is not the normal infinity wiring. But as I said weird things can happen use a battery. If the woofers are out of phase the air more or less cancels itself. You may even risk damage from over excursion. That said I am only talking about dual woofers in the same enclosure. Any other Tweet or mid may be wired out of phase due to crossover effects. I'm sure if you are getting solid bass yours are wired correctly but try the battery test. If wired incorrectly you are in for another experience.
Seems like I remeber my wiring as red pos purple between the speaks and black/ red stripe neg.
