ugornot
Poly Woofer?
OK just pulled the woofers (on my IIIBs) to make sure. What I wrote above is correct except the negative wire is red/black stripe. I offer this logical proof of out of phase. Gently push in on one of the woofers the other should extend to cancel out the motion. This is out of phase and results in little to no sound. In this sealed enclosure the woogers got to move in the same direction as each other under power. If you are remembering correctly and there is nothing weird about the wiring you are in for a real treat if you get these in phase. The one thing the infinities have over my maggies is impact. Please check and make sure they are in phase. If once in phase the bass is to much for you try the tone controls. This is the third set (My 4Bs, op 4s, and your IIIBs) that I have heard of being miswired. Makes them sound a lot like the little monitors they sell now days. (No Bass.) There really is no need for a sub with these middle infinities unless you are wholly into organ.
