notropey
So I have a RT-707 that I picked up a couple of days ago, this is my 3rd so I know them well. The problem it has apart from being butchered by its previous owner is that when a tape is played on it, there is no audio out via the line out or headphone jack forward or reverse, well there is a very very faint sound. Same goes if I have an input coming from the line in and source button on. The path is clean, the heads are clean, the pots are clean and turned up. I have even adjusted the internal pots, slight increase.
I'm thinking the issue is on the Playback Amplifier Assembly RWF-069. Now as this is a very common deck I was hoping somebody out there has experienced the same issue and might be kind enough to point me in the right direction?
Oh and how the previous owner got around this issue he drilled holes through the back and directly solder rca cables to the forward head only(essentially making it a RT-701) then hooked this up to a Shure Pre-Amp then into an amp. Crazy but hilarious.
Thanks for any help
Thanks for any help
