Start response/
Hi o0OBillO0o,
Well, bi amping vertically would still put 450 watts to woofers and 450 watts to the highs, which is not the same a s running MONO, which would put 900 watts to all ( except the MC452 does not go in mono.) as the woofer needs about 10 x the power the mids and highs do, providing more power to woofers would be advantages over bi-amping. ( and yes, the crossover does distribute power, by raising the impedance at frequencies where you want less power, all speakers work this way.)
The reason to suggest horizontal bi-amping is related, the WOOFERS need all the power, in horizontal, if the effort of driving the woofers causes the amp any stress, this would show up as increased distortion, however, a bit of distortion is quite difficult to hear in a woofer ( and they are typically about 3% to start with).
With the woofer amp doing all the hard work, the upper amp, connected to the mids and highs, is totally loafing and will stay super clean, which is more important in the mid and highs, where the drivers are cleaner and more sensitive to distortion, and in the frequencies where you can more readily detect distortion.
In a vertical bi-amp, each amp is still driving a woofer and more likely to be stressed on hard to drive speakers, if the amp is stressed, the audible artifacts of that stress will be in the mids and tweets as well, so,
Horizontal bi-amping will provide cleaner sound.
Does that help?
Chuck Hinton
McIntosh, Wadia and Snell Tech Support
McIntosh Sales Admin
Toll Free: (888)-979-3737 X311
Binghamton New York - "The Original Silicon Valley"
Sent: Wednesday, December 09, 2015 3:19 PM
To: Support
Subject: Ask An Expert
Dear Administrator,
I am sending my details using Ask An Expert Enquiry form at McIntosh Laboratory, Inc. Please find my details below.
Enquiry for:
First Name: [redacted]
Last Name: [redacted]
Email: [redacted]
Country: US
Date: 12/9/2015
Question/Comments: Hi there! Take a peak at the McIntosh XR100 manual,
http://www.mcintoshlabs.com/us/Prod...Name=McintoshDocumentMaster/us/xr100om-01.pdf Turn to page 13. You'll see what looks like two MC452, 450 watt per channel,stereo amps hooked up in horizontal bi-amp configuration. While not truly physical separation in channels in the diagram, I am sure one could switch to a vertical biamp config and then call it monobloc. Now, can some one tell me why this method is the example given by McIntosh? Is this a prefered method? At anyrate, I like it and it makes me want to buy two MC452s. I also have a running thread of what makes me laugh out loud, below.
http://www.audiokarma.org/forums/index.php?threads/running-mc452-as-monoblocs.692504/You guys are the best, o0OBillO0o
/End response
Well, we all learn something. Thanks team.
