Chuck's reply doesn't dispute whoareu99s, it complements it.
No doubt, but active... I posted this a while back..You still have full range going to both amplifier channels, this is what I have a problem, you don't gain any more headroom, you might as well run one amplifier....it achieves nothing..
All that is useful about this, is to sell more amplifiers......
If you are going to run out of headroom with one amp, you will run out of headroom with two doing this ridiculous (in my experience), passive bi-amping..
MEN220 Voicing Tool
Now we're on the same track. I was fantasizing about that in the last few weeks. Even lurked on the Audioclassics speaker section. Yep they've got 'em both for sale. *sigh*If you're pockets are deep enough to afford a pair of MC452s and XRT1ks, then I'm thinking an MEN220 is chump change.
One would be far better of buying two MC601s
Bill also has 2 MC275sBut then you would only have 2 channels of amplifier, 2 x MC452 gives you 4 which you need for active bi-amping...
1.2KW's on the bass, and 601's on the tops!! Brilliant!!Bill also has 2 MC275s
501s or 601s, 500w or 600w on the woofers
275 bridged parallel mono @ 180 WPC for the highs...
This setup will also give true channel separation that mono blocks are known for. Plus the nice combo of tubes with lots of SS power.
So what happens if you are bi amped with electronic crossovers ...
Is the assumption the amps are connected directly to the drivers, or still going through the speaker's internal passive crossover?
