SA-7100 Ripple Current measurements-effects on protection board?
Thinking out side the box - turn off any LED or fluorescent lamps in the room - there has been a few cases where the problem was external. Just a thought....
I want you to put direct shorts across your RCA inputs from the ground connection on the jack to the center conductor - perhaps making up a few sets of shorted plugs for the inputs (tuner, aux 1, aux 2, phono 1, phono 2) to see if there are any changes with different shorted inputs.
Touching the chassis and making such dramatic changes (37.5 to 39v) should not be possible.
There's something basic (and wrong) at work here.'
The unit does NOT have "death caps" or safety resistors (2.2 megohm)
It shows a grounded shell transformer with NO powerline neutral reference locations.
Normally the chassis ground is connected to the unit's neutral power plug prong with a 2.2 megohm resistor which is used to steer the power transformer's capacitive leakage current in a predictable direction.
0.1v of ac hum at the speakers is surprsing.
what do you mean by plug orientations 1 and 2?
Turn off and disconnecte the unit from the power line, and with the plug out in midair and the power switch turned on, take an ohmmeter reading between the metal chassis and the power plug pin(s - two readings) - it will probably be millions of ohms, but that's ok.
Back from break. Shorting plugs inserted into connections above above had no effect. I also checked the resistance between chassis and power plug pins. Both pins registered as infinite on an autoranging DMM. I did notice that the quality of the buzz changes when I engage the Tone Defeat switch, and is also slightly reduced when I engaged the -20db muting switch. Finally turning off overhead CFL had no effect.
Had some free time this evening, so thought I would double check the pre-outs and main-ins using another unit (Unit B). SA-7100 Pre-out into B's Main-in produced a buzz in left channel, I switched the L and R connections into B to double check, and buzz followed the left channel-out from 7100. The other way around(Unit B Pre-outs into 7100 Main-in), I could hear the signal from Unit B (AM radio in this case), but there was a 120 hz humm/buzz underneath it. The buzz from the control amp is much harsher sounding.
I then tried to go back to my poor-man's oscilloscope or audio signal trace. I connected the grounds of both units, and then put a DC blocking cap in the probe path. I had done this before, but for some reason tonight, regardless of where I put the probe (chassis, or any pins ), I kept getting a buzz, not sure why. In one sense this might be a validation of my "2 problem theory", in that the main amp has a 120hz issue, and the control amp, or upstream, has something going on with the left channel (and possibly something related to the 120hz issue on main amp). I did try turning off lights to double check that they weren't causing the problem.
Any suggestions out there?
Realized that shorting plugs were responsible for finding buzzing everywhere when using audio probe last time. Today removed all shorting plugs and no buzz when touched chassis or grounds. I poked around the control amp. The gate on the FETs (Q1 and Q2) was quiet, but both sink and drain had the buzzing. Disconnecting the jumpers, I tested inputs to main amp: quiet, but output also had buzz. Perhaps I'll see if any particular set of shorting plugs sends buzz to chassis.
And the testing continues:
Findings, (inputs and outputs refer to audio signal)
Main Amp
1)with pre/main jumpers connected, there is no buzz at inputs to power amp, despite buzzing at outputs of control amp.
2)If I enable Tone Defeat, I get some buzzing on left channel input, but not as strong as control output. No effect on right channel input
3) buzzing at +B and -B pins
Control Amp
1) no buzzing at +B and -B pins
2) buzzing at output pins, and all those related to the tone controls
Equalizer Amp
1)Buzzing on outputs, not on inputs
2) Base of Q1 and Q2 had an odd, almost heartbeat sound. Maybe 2 sets per second, with each set having two beats close together.
3) very faint buzzing at +B pin
Finally, not able to recreate chassis buzz. I had all 6 shorting plugs in when it happened, but using one plug and trying the different inputs didn't do anything
Happy 2019 everyone! Hopefully this will be the year I fix this unit! I had a quick question. Using an audio probe, would one expect a buzzing on the outputs of the full-wave bridge rectifier? MTF made a comment earlier on about the possibility one of the snubbing caps being shot, but I don't know if that would explain the buzz I hear at the pins ( 6 and 7 ) that correspond to the output of the bridge rectifier (these go to main amp board). The pins from the other rectifier are different: 12 and 13 are quiet, but 11 has a faint buzz that is lower pitched than that at 6 and 7 (more of 60hz hum I would guess). Is there a way I can check that the transformer isn't the cause?
Woah! I moved the grounding wire that connects to pin 10 on the main amp away from some neighboring wires (see attached pic), and noticed that it greatly reduced the hum/buzz on the power amp when I disconnected the jumpers. Left it in place, that is to say away from other wires, screwed the bottom back on and tried the unit out. Plugged my phone into the Aux 2 input, and with the audio probe started testing inputs and outputs of the different amps. Bad news: with Tone Defeat Turned off, no signal reaches the main amp. Great news: with Tone Defeat engaged, I get perfectly clear output!? At first just tried output pins of main board, but plugged my headphones in and Voila! Buzz is gone. Not sure why, or if it's indicative of a more serious problems, but I'll take it. Now to figure out what is up with the Tone Defeat Switch. Still can't believe it......
Alas, my joy was short lived.. Last night I tested it again after writing, buzz was there, but then went away on its own. Today I fixed up the tone defeat switch, all kinds of gunk on the inner part was not letting the signal go through. Reassembled, and buzz is back, but at least signal is making it all the way through this time. Much louder when tone-defeat is not engaged, and also dampened with the muting switch, so somewhere after flat amp I would guess, will have to bust out the audio probe again. Odd thing is when touch the outer parts of the pre-main jumped jacks, or the on-off switch with my hands, buzz gets a bit softer, also if touch the power switch. Moving the back grounding wire also changes the intensity. So at least I've had a few windows of no buzz!
SO CLOSE! PLEASE, PLEASE! I hope someone can help me on this last bit. It turns out that if I touch the exposed metal end of capacitor C11 on the power supply board and the chassis with same hand, the buzzing goes away completely! Capacitors C2, C4 and C5 had a similar effect but wouldn't kill the buzz completely, just reduced it. None of other capacitors on that board displayed a similar behavior. I tried touching the side of C11 instead of exposed metal end, or pushing on the exposed metal end with a plastic tool instead of my finger, and neither had an effect. I think this would argue against a bad solder joint, but not convinced of my deductive skills anymore. I lifted the board off the plastic mounts to look at solder joints, and in this configuration, touching the exposed metal ends of either C2, C4, C5 or C11 reduced buzz, but didn't eliminate it completely. Same with touching Pin 14 (ground for C2,4,5, and 11). This most likely indicates a grounding problem, but not sure what else to do. I truly hope someone can point me in the right direction, I feel like I almost there!
edit: added a jumper between Pin 14 and Chassis. Buzz reduced even with board not on plastic mounts, but now "just" touching the exposed metal end of the capacitors listed above gets rid of buzz, don't have to touch hand to chassis as well
hmm. More testing, and unecessary action. I tried jumping negative pins of either C11 or C2 to chassis and that removed buzz. As I mentioned yesterday, jumping Pin 14 to chassis reduced buzz, but did not kill. Jumping the negative leads of either the 4 caps to Pin 14 or to each other didn't help. Thinking it might be a bad grounding wire, I removed the wire-wrapped grounding wire between Pin 14 and grounding pin( on a soldered and screwed on grounding mount) and replaced with new wire(no wire wrap tool so attempted to solder). Of course this didn't help, and probably made things a bit worse. Still get a reduction in buzz when jump Pin 14 to chassis, and negative capacitor leads to chassis now ALMOST gets rid of buzz. I'll try cleaning off the grounding mounts tomorrow and see if helps, seems that something is bad at the grounding mount. ARGGHHH
SOLVED!!! It turns out that something was wrong with either the wire itself or the connections at pin 14 on the power supply and the grounding prong that is welded and screwed to chassis. My first attempt at soldering a replacement wire was a mess, and I didn't clean off the oxidation or rosin flux residue from the pins. I went back, de-oxited the pins, then scrubbed with some fine sand paper. I improvised a wire-wrap tool using a plastic ball point pen insert (idea from instructables), and miraculously that fixed the problem! I added solder to the improvised wire-wraps since it's not a "proper" wrap. I can't believe it, 2+ years in and the unit's buzz is gone. It was dumb luck that I found the issue, I had just happened to test the capacitors by wiggling and noticed the change in buzz when I touched chassis and exposed metal end. Damn.... Now to change the trim pots and then onto the next unit!
Back on post #5 I asked you if the grounds for 10 and 14 were OK, I guess I was half correct all along! Good you finally found the problem and as always it was something stupid. :)
Craig
Hi Craig, good call and thank you! I guess I should ask if there is a "proper" was to check grounds. Back around the time of your post, I tried connecting a jumper for all the grounding pins on the different boards to chassis (one at a time of course). I also checked for continuity with all those pins. As I found with Pin 14 a couple of days ago, jumping it didn't get rid of the buzz. It was the combo of the existing ground wire AND touching the capacitors (and then jumping capacitor negative terminals to chassis) that was getting rid of the buzz. Any suggestions for future grounds testing would be greatly appreciated!
i sometimes check grounds by measuring voltage between 2 points .like from ground pin to chassis . a wire should have very little voltage across it if any at all .
Sometimes a meter just isn't enough as there is no real current being drawn, once current starts flowing it's a different ball game.
Hi Everyone, unit has been working well, put it into rotation with a tuner. I did notice that when I power it up, after the protect circuit does its thing, there is about a 3 second window of hum or buzz, that goes strong then fades out. Is this relatively normal behavior, or indicative of a potential issue?
Check the number of seconds the unit stays in protection from turn on until the relay clicks. The relay may be closing early.
I've seen this attributable to a bad cap or a failing transistor in the relay timing circuit.
When ever I had a unit with those kinds of problems and it begin to be frustrating I would solder all of the wire wrap connections, any chassis ground soldered points and any ground under a screw and more than once it fixed the problem. Trouble shooting a problem like that can be quite frustrating and it's just feels good to solder all those mechanical connections, and sometimes you fix it that way.
