Segasonic91
I got around to starting on recapping my SA-7500 yesterday. I also replaced the faulty 2SC1451 transistors. I only capped the two tone boards and the two teansistors so far. I discovered that I did not have the bi-polar caps I thought already arrived so I decided to put it back together until I have everything.
I tested it tonight but the relay was not kicking in. I am guessing it is the 2SC1451 transistors I installed. They are new NEC models which I thought would be fine as it is like for like. I installed with the little lip on the transistor facing "up", the direction of the arrow on the board.
I discovered that I did actually buy 2 KSC3503DSTU transistors which I will install tomorrow. I am just wondering how they are installed? They are marked as bi-polar so does it matter which way they go in? Should the numbers on the plastic be facing towards the front of the amp?
Thanks!
Thanks!
