Decided to change the transistors on the eq and the volume board and swap those caps I mentioned around. I also changed some of the caps on the switch board.
I discovered a missing cap so had to put an old one back in until I buy a replacement.
So I tested it and no damn click again. Placed on ths bottom plate and placed the top on it and tried it again. Lucky I had the top on, a few seconds after I switched it on, there was a lound BANG and smoke. I do not know what popped though. Something did, because there is fluid on top of the lid. It was something on the power board cause I saw the sparks, and that is where the liquid is.
No idea where to go from here. What could have caused it? The transistors were all in correctly and so were the caps. If there was a cap in the wrong way, could that cause it? Also, what could have expelled liquid other than a cap? I don't see any popped. I thought it might be one of the power transistors.
Edit: Found the popped cap on the switch board, so I guess I put one in the wrong way around. I have never, ever done that before. I always triple check, I guess I was too tired tonight. Bugger.
