petehall347
the brandy coffee man
did you change the capacitors yet ?
Yes, all new capacitors installed on board.did you change the capacitors yet ?
will need to wait until the amp cools more. Just tried reading pin 16, but after 15 minutes the amp did not drop into protection.need to see pin 16 and 17 voltages before deciding if supply issue or not
What should I measure once I pull Q5? (you meant Q5 as you mentioned before, right?)did you pull d5 yet ?
OK, then I'm just watching to see if it falls into protection with D5 out?D5 . it cuts off the over-current sensing when out of circuit ..
then see if circuit behaves itself .
