QSilver
I've been going through doing a recap of this beast which has gone well - as well as replacing a number of resistors that were looking past their best...
Before the re-cap and after, I have noticed that on first powering the amp on, the left channel works fine but the right channel isn't there at all or is very weak and distorted until you give the volume a boost. Then it kicks in loud and clear and will continue to work if you turn the volume back down. The volume and all other controls have been cleaned with Deoxit. The volume had been crackling a little but that's stopped now.
I've tried looking for the problem and I haven't managed yet as when its on the bench, it doesn't seem to do it as much! My thoughts are that it might be a problem in the tone amp section as that seems to be the last thing after the volume control besides the NSA amplifier.
Are there any places I should check first or am I looking in the wrong place?
