whitecastle
Partial to Pioneer
Hey folks. Just had a couple questions before I consider a recap of my SA-8800.
I was looking over the recap list for this amp here.
I noticed it does not list replacements for the 4 x 12k 63V Caps mounted on the PA assembly (AWR-182).
In p18 of the service manual, these are shown below the PA assembly and have the code: ACH-209 listed below the cap specs.
Is there a reason why these 4 caps would not be included in a recap?
I was looking at these as replacements.
Also, the UKL1E100KDDANA cap for the TC is out of stock until the new year. It is a 10% cap, but 20% alternatives are available. Is a 20% acceptable, and if so, what kind of difference would it make?
Lastly, I'm wondering if anyone has any suggestions on the following issue I'm trying to diagnose.
Sometimes, when I power on my SA-8800, I hear a crackling/fizzing/popping and the LED and Fluoro meters will flicker as the amp powers up. Usually after 3-5 seconds I'll hear a distinctive "click" and everything then seems to work fine. Usually this is one a cold start.
Will recapping the PA address this, or is this an issue with the power transformer? If a recap is the solve, are the proper caps included on the list above? If it's an issue with the transformer, can I service it?
Appreciate any advice. Thanks!
