sa-9100 sa9100 awg-018 awg018 parts list
Which parts did you use???
awg-018 c1 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c2 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c7 47uf 16v cea 647-UPW1V470MED1TD 47uf 35v
awg-018 c8 47uf 16v cea 647-UPW1V470MED1TD 47uf 35v
awg-018 c9 3.3uf 25v cssa 647-UKL1H3R3KDDANA 3.3uf 50v
awg-018 c10 3.3uf 25v cssa 647-UKL1H3R3KDDANA 3.3uf 50v
awg-018 c11 47uf 25v cea 647-UPW1V470MED1TD 47uf 35v
awg-018 c12 47uf 25v cea 647-UPW1V470MED1TD 47uf 35v
awg-018 c13 4.7uf 25v cea 647-UPW1H4R7MDD 4.7uf 50v
awg-018 c14 4.7uf 25v cea 647-UPW1H4R7MDD 4.7uf 50v
awg-018 c17 10uf 25v csza 647-UKL1H100KDDANA 10uf 50v
awg-018 c18 10uf 25v csza 647-UKL1H100KDDANA 10uf 50v
awg-018 c21 100uf 16v cea 647-UPW1H101MPD 100uf 50v
awg-018 c22 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c23 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c24 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c25 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
awg-018 c26 1uf 25v cssa 647-UKL1H010KDDANA 1uf 50v
Q1, Q2, Q3, Q4
2sa774 metal can bce 35v 50mA 0.15w 540hfe 65mhz
512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
Q9, Q10
2sc1478 metal can bce 35v 50mA 0.15w 540hfe 150mhz
512-KSC1845UBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
Q5, Q6, Q7, Q8
2sc1312 to-92 ecb 35v 100mA 0.2w 500hfe 150mhz final I = 5mA , final w = 0.08w
I had asked for the list and was willing to look up the parts, as I have a 9100 in the wings, and if you wanted to share effort, you would have done the entry, I would have done the selection, and we both would have used the same (best) parts... and the list would be available to everyone in perpetuity.....
I used the same updated guidelines in parts selection that I used when I rebuilt the sa-9500 and got the spectacular results.
Going from 25v to 35v should be fine - I recently rebuilt the control amp assembly in a SA-9100 (replaced every single capacitor and transistor) and the thing sounds fabulous!
I got the parts list vicariously from Mark by using the google search engine. Google searches audiokarma much better than audiokarma searches itself.
To search Google for only one website's results, type something like this:
pioneer sa-9100 site:www.audiokarma.org
That will tell Google to only display results from www.audiokarma.org - VERY useful!
Q1, Q2, Q3, Q4
Q9, Q10
Q5, Q6, Q7, Q8
