Backlight
I also have the preliminary information about the addition of the transistor regulator:
On the awm-163 protection assembly, pins 9 to 11, a 1600 ohm 2 watt resistor is added.
The wire from pin 9 on the awm-163 protection assembly going to pin 10 of the awv-002 indicator assembly is interrupted. This wire will now go to the base of an NPN power transistor.
Instead, the emitter of that NPN power transistor will be connected to pin 10 of the awv-002 indicator assembly
Finally a NEW wire is needed from the collector of that NPN power transistor to the +68 volts, either from pin 6 of the awm-163 protection assembly or pin 13 of the awr-194 power supply assembly.
Then all you need to do is to figure out where to mount the transistor, and either put a heatsink on it, OR do an INSULATED mounting to the metal chassis somewhere convenient to carry away the heat.
The transistor will be an NPN power transistor capable of handling 100 volts, over 100 milliamps and dissipating up to 4 watts of power (or more). It can be to-220, which will need insulating - because the metal case is energized, or it can be a TO-126 case, which would NOT need insulating.
We MIGHT want to add a small capacitor 20 to 47 uf (80v) across the 1600 ohm resistor, which will then closely imitate the sx-950's Q5 regulator circuit and preclude any chance of oscillation.
I have build this regulator with success! The regulator keeps the voltage stable under all circumstances. But the 32VDC was not giving the best results I found out after testing with various settings, including the voltage on pin 7 on the indicator board which is now 19.5 volts with the replaced 18V zener and 330Ohm resistor.
I did some little tweaking and ended up having an additional 330Ohm resistor between the emitter and pin 10 on the indicator board. This keeps the voltage on pin 10 around 28VDC in bright position, which makes the display look better than the 32VDC it was without the additional resistor. And I preferred this solution over replacing the 1.6K resistor with a lower value which would not only cause a lower voltage on the transistor base, but also draw a lot more current away from the 68VDC line...
I also installed a 47uF/80V (Nichicon UPW) cap across the 1.6K resistor.
I positioned the transistor on the side chassis panel below the speaker switch. It can dissipate its heat easily. But is this the best position since it is not shielded and is quite near the tone amp board? Any comments here?
And another thing: does the additional usage of the 68VDC line affect the sound in any way? Is that possible?
Nevertheless, the display, in bright position, looks quite similar to the displays of my SA-7800 and SA-8800 now. It is slightly less bright on the right end of the screen, but acceptable. The display is not functioning according specs anymore, that is sure. But I hope it will as it is...which is acceptable.
Any comments or questions on this modification?
And if there still is somebody out there with voltage readings of a properly functioning SA-9800 display, please reveal yourself!
