Have you tried adjusting the dc offset (from 210-240mV) using VR3 and 4
as per chapter 8.1. You can skip the 5.1k short/resistor just to ballpark.
Does the offset respond to adjustment?
Referring to the sm, the amp has,
- Over Current Detection
Measure voltage between Pin 1(red) and pin 2 (black) on power amp board
Measure voltage between Pin 8(red) and pin 2 (black) on power amp board
Measure voltage between Pin 9(red) and pin 16 (black) on power amp board
Measure voltage between Pin 15(red) and pin 16 (black) on power amp board
(don't expect much)
Has C20 (100uf/16V) and C21 2.2uf/25V in protection circuit been replaced?
Long shot that C21 is breaking down under the extra voltage
Still need to check out voltage inbalance as per sm.
(don't expect much)
