Burialcloud
I bought a SAE 2400L this week for 350. It was in “working” order but I figured it would probably need an overhaul before use.
Got it on my bench today and channel B seems great. Was able to get the offset and quiescent dead on. (Don’t have a distortion analyzer to check bias unfortunately)
Channel A, however, wouldn’t get quite where it needed to be. DC on the outs stays around 540 mv or 1/2 a volt. When I adjust the trimmer it’ll jump down temporarily and then quickly level back up to .5v. Quiescent was way high when I first checked, brought it down to 1.7 on one resistor and 1.6 on the other. Again close but not within tolerance according to the service manual.
So, my questions. Sorry for all this. Is it likely these issues will be fixed by a simple recap/restore job and what all should I change? Should I spend the time taking all the output transistors off to clean everything and add new goop and those little heat shields. (And where does one find those little guys)
Does anyone have a general parts list or a guide for a general restore on one of these? I’m seriously considering buying the 185$ kit on eBay from hifiaudio.com but damn that’s $$$. They said they would have their listings back up asap so I got a few days to decide if I’m willing to dump that much. Any suggestions on if this is worth it? I checked the transistors temp on channel a’s preamp board to see if any were overly hot but they all were relatively similar and none were seemed super hot. Can just drifted caps and various other small parts be causing my offset issue or does it point to something more serious?
I saw a thread concerning the mod to get rid of thump when ya turn the unit off. Sorta followed it I think. Not sure if I’ll perform this mod. Is there any risk in not doing it or just the annoying thump? Cause that is something I can live with.
I believe I will replace the wires going to the rca jacks with some good canare. Stuff in there looked pretty thin and junky. Is that an ok idea? Should I do the same on the speaker wire?
Are these sprague caps across my speaker outputs stock or is this some sorta weird mod I should get rid off?
I wanna do this thing right and haven’t plugged it into a speaker yet as I wanna get it all dialed in first. This amp will be powering passive speakers/monitors in a studio/mixing setting. Clarity, soundstage, and reference quality are very important to me. I’ve been told a few times I should get a bryston and be done with it, but I’m a big SAE fan and have the entire 02 series for my home setup.
Will this serve me well or should I move it to my home gear and grab a bryston 4b like all the engineers keep telling me?
Thanks in advance for any help you can offer. I’ve done some work on non tube gear but I am still very much learning in general as I go. It seems a fine specimen to rebuild and enjoy.
