FootFungus
There are resistors in the pre-driver section that need to be closely matched. You might as well go 1% metal film when replacing the resistors. I think the schematic specifies that the originals are all 1/3w or larger.
There is a lot of work in that amp. It was top of the line and very fine sounding. Definately worth the trouble. Contact me if you need the bias IC. I may have a few in my parts box.
Thank you kotofei, I will follow your suggestions. Resistors are cheap and I really just want to do this right so it lasts for many years to come.
Should all of the resistors be changed on the driver boards as well? While we're at it, I've heard there is usually no reason to change the little ceramic disc caps. Does anyone change them anyway while they are doing the work or would that be totally unnecessary?
A worthy investment might be a Hakko 808:
http://www.amazon.com/Hakko-Desoldering-Kit-With-808/dp/B000ARPULW
I love mine. Very effective and fast.
Get a handheld solder pump. Cost approx $5 in the Ebay. Helps A LOT in projects like this.
The Silpads don't need grease. Go ahead and clean out all the gunk you can in the pin and heatsink holes if you haven't already.
You could use a thin coat of regular ceramic heat sink compound for the heat sinks. That is what was on my Sansui 9090.
Watching with interest and to learn. Got a couple amps I need to go through. Steady as she goes Rob!!![]()
