Rob41
Don't stop believin'
It's alive! I took a relay from a SAE 2201 I need to repair so now the right channel has a working relay but, still really low sound in the right channel. I started looking at the meter board which the pre-drivers go through. Although I originally had changed nothing, it appears the last guy who tried to repair it had the gain wires reversed. The right channel now sounds just as good as the left.
There are still a few things I need to do before it's done.
1. Order the correct diff pairs for the pre-drivers.
2. Once installed, set the DC offset for both channels.
3. Set the bias.
4. Double check the DC offset.
5. repair one bulb socket for the right meter.
6. Sit back and enjoy the music.
If I'm forgetting anything please let me know.
I have run both channels for 5 minutes or so and it seems to be running very cool. I don't feel much heat rising from anywhere although I haven't taken it up past 4-5w. For all I know the bias is way off from the last repair job so I don't want to run it any more until the bias and DC offset are dialed in.
So I've got to get through a few more steps and my first recap/repair will be complete.
3. Set the bias.
