I changed all electrolytics. Checked the voltages across the zeners which seem to be ok.
Changed two 150 ohm resistors on a channel (drifted to 175), changed one driver pair on a channel (had one sub and one original, so took the usual KSA1013/KSC2383 subs we see on the forum).
Also checked all parts after the voltage regulator: all resistors ok, tried a new transistor for bias setting, nothing improved.
Voltages are all ok at the STK3042 except for the two outputs which are not -1.5/1.5 but something like -0.5/1.8 hence the DC offset.
I took another 3042 from an Akai amp I have stocked for years but this didn't solve the problem had generated the same DC as with the other 3042.
I was quite surprised but can't know for sure if both 3042s were bad with the same failure or if something else in the SAE is causing the problem.
I checked most parts around the 3042 and they seem to test ok (all resistors in value).
The question is what is a serious source for the STK ? There are plenty on ebay at various prices andI wonder how good they are and if they are not counterfeits as lots come from Asia. Moreover, anybody knows the difference with the STK3042, STK 3042 II, and STK 3042 III ?
What I need to know is the voltages of all zeners. I did a crude test by checking the voltages across them on both positive/negative parts and they are almost same.
What I also found is something like 150mV at both inputs of the 3042 despite the new Elna C401/402 (I have 0V before them so the voltage must come from the STK).
What I must say is that three of the output transistors were replaced with Sanken subs (can't recall the values now as I closed the amp and put it on hold).
The relay clicks after two seconds so I presume that the small TA73xx IC is bad, most probably due to the damage caused by the channels when they got short (and not repaired in the clean manner).
Sooo..... I keep wondering what can happen. I would be really surprised that both STK3042 ICs show the same trouble AND with the same resulting voltages.
Thanks for your hints !
