At least for HD signals, Not sure I understand how there is any sound quality plus or minus imparted by the unit itself no matter how good the caps are since it should just be passing the HD digital bitstream to the outboard DAC. All it has to actually do in that case is be decent at locking onto the signal (I could see component quality having an impact here).
Considering it will be connected to an Mc preamp with their DA2 DAC built in, and having recently auditioned an MR88 for about a month (itself a DSP based tuner)… I’ll be very curious if there’s anything approaching 4-5 grand of difference between these two units. My suspicion, much as I may like the aesthetics of the MR88… is probably not. It excelled in terms of the HD feed, but was somewhat thin sounding and a bit lifeless on the standard FM channels. No matter, as the standard FM in my area wasn’t terribly great to begin with, but many of the HD sub channels I did enjoy.
So just to follow up on this… the HDT-20 arrived and I’ve been putting it through the paces. Unpacking it I actually observed that my unit was a 2021 build. So these are or still were being produced with fresh components very recently.
I should also say that while this is no MR88… there is no shaming this unit’s build quality overall. The case feels good, is of decent weight, and the buttons have a nice tactile push to them. The black brushed front panel is also low key and avoids calling much attention to itself. The rotary tuning knob which appears to be plastic or a very thin metal also has a nice feel to it despite being a simple rotary encoder. The display contains much useful information and has a good range of adjustable brightness from completely off to searingly bright. Since the clock display never turns off my suggestion is to use either 0 (off) or 1 (the dimmest setting) for most average lit rooms. The unit will illuminate the display at the next highest brightness setting when you interact with it. So for 0 it will light up briefly at “1” then turn back off. For 1 it will illuminate at 2 briefly etc. The only problem with the 0 setting is that the next up brightness level is too dark to see any useful information other than station info from a reasonable distance. Considering the number of comments about the worthless clock, I didn’t even bother setting it. I did set the clock menu setting to “auto” but it never did set itself.
As for audio quality… Initial impressions are very good for the price range it’s in. In fact, on my system I have not noticed anything approaching “dry” or lifeless sound on either the HD feeds or the standard FM broadcasts. Though admittedly I don’t have much interest in the standard FM so I haven’t spent much time with that. In fact, as has been noted before you can’t force HD off so if the channel broadcasts it and the signal is of sufficient strength you don’t have a choice except for the few seconds occasionally while it’s locking on. Which brings me to the greatest shock being that the sensitivity in my area is every bit the equal of the MR88 with a cheap Radio Shack desktop antenna that’s nothing more than a small black box with a flimsy coax wire. Channel lock in FMHD is about the equal time wise. That is to say that neither the 88 nor the HDT-20 took so long as to have me notice it. Another definitely pleasant surprise was *AM* performance, especially considering I just kind of threw the AM loop behind the entertainment stand after I connected it and didnt give much thought as to its placement at all. Again, I no longer have the 88 but from what I can recall the total stations found and received clearly seems equal if not better with the HDT-20.
The HD feed, connected via optical toslink to the DA2 DAC module in an Mc preamp has a very full bodied sound, though never overly warm or muddy. In fact, when it comes to the lower midrange and bass performance… the HDT-20 might actually be slightly ahead of the MR88 but that’s purely from memory so take it with a grain of salt. Punchy, clear, and well separated left to right would be the highlights there.
So that’s the good… unfortunately the one area where the HDT-20 falls short… perhaps well short of the MR88 is in what I call “high frequency compression artifacts”. Not sure if the MR88 is applying some kind of filtering to mostly remove this after the fact or if it just had a better DSP, but if you like to really crank the music this high range compression will become more and more audible, especially as the volume increases. It’s not terribly distracting, but it’s definitely there. Just something to keep under consideration if you’re bothered by this.
So in the end, is the MR88, which now routinely sells in the 4-5k range when they come up… worth 4 grand+ more than the HDT-20? No, not by any reasonable measure. However it might well be worth 1000-1500.00 more and some people have found those quite cheap with a lot of looking. So unless I run across another 88 in the 1000-2500 range… For the price, I can’t really complain.
