Gents thanks!
I cleaned the face and replaced the dial fuse lamps that were out and it looks very clean.
I ran it again tonight for about an hour. Overall volume sounds even and without distortion. I'll clean the pots as I can't remember if I did so yet. There are also a couple of tiny caps running from, I believe, the volume pot that need to be replaced.
The left trans is warmer than the right but it is not hot to the touch. BTW which tube is the rectifier tube?
I also have popping when I change the selector from Aux to Tuner etc.
The tuner is not very sensitive at all (I am in a basement but other tuners work well) so it must need aligning.
