sansui 1000A resto.
hinodit
Airborne Army Ranger
I need help infinding some one who can restore my sansui 1000A rec. It is a9/10 cosmeticly truely a beautifull unit. I really need to have it recapped and restored. Any suggestions ?
At the risk of offending you, the original question was placed at 11PM last night. You might want to wait a day or so for an answer. The Sansui 1000A is a wonderful receiver and is certainly worth restoring. Made in the late 60s, I guess that waiting a few more days won't be too long.
Hope you find someone!
You are from Pardeeville WI, how far from Wausau are you?
Does your Sansui play at all right now?
I am not to far from wausau. It only plays on the tuner right now. Its all i have tested.
Playing is OK for a test, don't push your luck please.
hinodit,
If your Sansui plays right now, you can be sure that the "expensive" items (power and OP transformers) are GOOD.:thmbsp:
Don't "push your luck" with using the receiver before is is recapped.:nono:
The original Paper In Oil (PIO) capacitors WILL short out if not replaced, the big can electrolytics MAY be OK for testing, but should be replaced.
Ventilation is a MUST with this receiver (they run HOT!):yes:
There are too many threads in the Sansui section on the 1000A to repeat here.
Once restored, you will NOT be disappointed! :no:
Mark T.:music:
