markuus3889
Diatom, what's that?
Hi,
I'm going to attempt to repair and do the factory modification on my Sansui 3000. This is the only receiver I own that doesn't work and I have the time to finally do the mod and repair.
I found this receiver along with a 3300 years ago in my dad's stuff. I tried it then not knowing anything about variacs or dimbulb testers. It worked briefly then smoked a small bookshelf speaker and I mean it smoked the thing. I tried new fuses and those blew in one channel immediately so I put it on a shelf and used the 3300.
Over the years I've read the 3000 or 3000a posts that come along to glean as much info as I can. I've got the parts to do the factory mod and am waiting for some trimmers and other stuff. While I was looking through the receiver I discovered someone has been into it before. Two of the four 2SC696 driver transistors have been replaced with ECG128(TR805,TR806) transistors and two output transistors are labeled SYL ECG87(TR004,TR005) and two are labeled ECG385(TR002,TR003) with the later having slightly different cases from each other(fakes maybe). As far as I can tell everything else is original.
So far output TR003(ECG385) has tested bad others are good and D807(SM-150?) is bad. I've tested the Driver transistors and they test fine albeit mismatched from channel to channel and this is as far as I've gotten.
I plan to change the drivers to 2N3439 and the outputs to MJ21196G. Predrivers 2SC292(TR802,804) test good and I haven't tested TR801,803 but I will.
I have started the factory mod and have the Capacitors mounted and wired and need to change the Diodes. I have 1N4002 that i will use but my confusion comes from the factory use of SW-05(D801-804) Diodes and SM-150(805-808) Diodes. SW-05 are used elsewhere in the receiver and I have seen that the recommended replacement is 1N5408. Would it be better to replace any SW-05 I encounter with 1N5408 or do as the mod suggests for the driver board diode replacement and use 1N4002, but then use the 1N5408 for the SW-05 on the Ripple filter board D001,D002 and D011(parts layout location G,3)?
Once I repair to working condition I intend to recap the unit, but am wondering if I should replace any electrolytics immediately or only as needed for the initial repair.
Thanks,
Mark K.
Useful Links:
http://akdatabase.com/AKview/albums/userpics/10004/Sansui 3000 Service.pdf.
http://audiokarma.org/forums/index.php?threads/my-sansui-500a-restoration.567262/page-3#post-7539608.
http://audiokarma.org/forums/index.php?threads/dead-channel-in-sansui-3000.6552/.
http://audiokarma.org/forums/index.php?threads/sansui-3000a-transistors.223721/.
http://audiokarma.org/forums/index.php?threads/sansui-3000a-restoration.387857/
http://www.audiokarma.org/forums/index.php?threads/here-sui-sui-sui.478057/.
http://audiokarma.org/forums/index.php?threads/is-unmodded-sansui-3000a-safe-to-use.569595/.
http://www.audiokarma.org/forums/in...p-me-figure-out-if-this-is-a-misprint.214689/.
http://www.audiokarma.org/forums/index.php?threads/3000a-mod-question.509180/.
http://audiokarma.org/forums/index.php?threads/sansui-3000a-speaker-prot-mod.647005/.
Thanks,
Mark K.
Useful Links:
