Sansui 4000: Persistent clicking/pulsating sound on F-1169 board (Jumpered version)
jpreza
Hello everyone,
I’m currently troubleshooting a Sansui 4000 receiver and have hit a wall trying to track down a persistent audio symptom on the F-1169 equalizer board.
My unit is running the version of the F-1169 board that features the two jumper cables on the back.
The Symptoms
  • Upon power-up, the receiver immediately makes a clicking and thumping sound (which replaced an initial "helicoptering" sound).
  • This pulsating noise happens right away and is present across AM, FM, and AUX inputs.
Work Completed So Far
  • Transistors: Replaced the four original 2SC871 transistors with brand-new KSC1845s. I have strictly verified and double-checked the pinout orientation.
  • Capacitors: Replaced the two 10uF 25V electrolytic capacitors with new 10uF 50V caps. (Note: The remaining electrolytics on this board are four pairs of 10uF 50V, 100uF 6.3V, and 47uF 10V and these have also been replaced with high quality Nichicon caps).
  • Result: Despite these replacements, the rapid clicking and pulsating sound remains entirely unchanged.
My Questions
  1. Because the noise is persisting across all inputs (tuner and auxiliary), could a leaky capacitor elsewhere on this jumpered board version be driving the circuit into oscillation?
  2. Has anyone experienced this specific pulsing behavior with the jumpered F-1169 variation? Should I suspect a breakdown in the jumper wires themselves, or look closer at the remaining low-voltage electrolytic caps (like the 6.3V or 10V ones)?
Any guidance or voltage checkpoints you could recommend for this board would be greatly appreciated. Thanks in advance!
Do you hear the sound using the tape monitor?
There are also two 1.5uf tantalum caps that really need to be replaced. I used Kemet films.
Very faint....even then I hear a clicking sound every 1-2 seconds. I don't have any film caps right now, but I have 2.2uF electrolytic caps that I can use in the meantime to see if that's the issue
thanks! yup I've been staring at these two pages all evening. Replaced TR 601, TR 602, TR 603, TR604 (which should really be Q but I digress) with KSC1845s. Since the KSC1845 is an ECB transistor on the flat side, they are installed 180 degrees from the above diagram. I've replaced C603/4, C605/6, C607/8, and C611/2.
