We have a Sansui 5000x that was purchased in July 1971 while I was in Vietnam. It has been used almost daily since I returned home. The right channel no longer works and the volume control on the left is very sensitive - like all the power is going to the left channel. The same is true for speakers A, B, C and headphones. The right channel doesn't work when I press Reverse or Mono. It also doesn't work on AM, FM, Phono1, Tape1 or Aux input. Switching speakers still results in the right channel not working. All fuses are good. When the left speaker is disconnected, the right speaker works and vice-versa.
The serial number is 811070035 and it has the newer F6013 boards. The only physical thing I have noticed is the plastic covering on a capacitor labeled ELNA 6.3V 220 uf on one of the F6013 boards is a bit wrinkled on top. The red arrow in the attached pictures point to the capacitor.
If it only an inexpensive capacitor, it would hate to give up on this unit even though it looks like it might be a challenge to access. (I know given it's age, a complete rebuild would be ideal but I am not willing to spend that much money on the project.)
Can anyone help with a diagnosis without getting too technical? The only diagnostic equipment I have is a multimeter.
Thank you.
Thank you.
