Both boards read a steady 82.5 volts on one multimeter and 81.7 on another. Since neither is an expensive multimeter, I assume the readings are reasonable.
It appears from your post that the picture I posted on Sunday at 2:05 PM above has the left and right amp boards labeled backwards. If so, my idea that the capacitor in my original post might be bad is wrong since it is on the right amp board facing the front of the unit. Please confirm that I am understanding your post correctly.
Is there anything else I could easily check?
Thank you.
Thank you.
