Zeus12
Greetings Audiophiles,
Here´s my progress report! Recapped the entire Driver Board, and also changed the "trannies" on the Sansui 661 Driver Board, which according to many people are prone to problems, the 2SC1124 and 2SA706 (TR06,07) and (TR11,12) respectively. Also changed the 2 (C21,C22) (0.1uF 50V MC) green caps. Cleaned the board and performed the DC Offset according to the instructions in the Service Manual. The trim pots, I have to say, are very unstable, just looking at them makes the DMM go crazy but I managed to keep it within specs, +-10mV. Sounds EXACTLY THE SAME as before. That fricking hum is still there, on both channels, independent of volume. I don´t know what else to do on the Driver board. Should I change TR09,TR10? On the Service manual they figure as 2SC1124´s but on the board, as you can see, they are "Sony 01124 DW12", and they are somehow "joined" with the TR07,TR08 transistors. If I take one out, they other will be left hanging.
Here´s the PSU, completely recapped, and the Driver Board along with the F-1499A from the Service Manual. Any suggestions would be appreciated!
In the meantime, should I go ahead and start recapping the Tone Board?
Cheers!!
Cheers!!
