Steady Eddie
I've replaced fusible resistors on the driver board, replaced all the electrolytic caps on the driver board except for the 470uf caps (C05 and C06) and I've also replaced all the caps on the power supply board except for the 10 uf caps (also C05 and C06 on this board) (somehow I overlooked these caps when ordering from Mouser)
I also replaced two zener diodes on the PS board that looked dodgy and two transistors.
Even though I didn't finish all the caps, I wanted to test to at least make sure that the unit still played, that at least I did not harm.
Right now, the receiver sounds a LOT better, the caps I replaced on the driver, I used nichicon FG series, and before it was popping much worse and farting out so bad I thought my speakers were blown. Now it sounds rich and detailed. But big bass transients make it pop, and there is some sort of protection circuit that temporarily shuts down the audio.
Am I on the right path? I will order the additional caps I missed, but I want to make sure that it's not a capacitor or other component on another part of the receiver.
