Steady Eddie
He's right, they don't *need* to be matched. However closely matching them helps to steady the fluctuating DC offset that is common for these boards. Plus if you use KSC1845FTA all from the same batch, they're usually pretty close anyways and work well.
I have one of these I use quite a bit. https://www.amazon.com/gp/product/B00O0BMNX2/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
And I have one of these for quick testing and identifying EBC, etc. Not super accurate, but close enough! And cheap too.https://www.amazon.com/Mega328-Digi...words=transistor+tester&qid=1569871168&sr=8-9
I made my own test leads using short pieces 22ga silicone coated wire, and minigrabber clips.
I will order the cheap one, I acquired a couple other receivers, including a Sansui 1000x, so might as well get what I need. Thanks for all your help!
Another question. The main board has the two main power supply capacitors and a few smaller electrolytic capacitors. Should I change those as well? And what is the preferred cap for the big ones? I've been using Nichicon FG for the audio path, but power supply caps aren't in the actual audio path...
They're tricky, but not "Saintly" tricky. But yes there would be two 4.7K that get replaced with modern 5K, and the other pair are 1K and will be replaced with the same but modern 1K. Bourns is my choice of brand.
