I’ll try these too cheers!I was thinking also R31/32 (100K) could be contributing to noise. The last thing is. the volume pot itself, not sure how, but I've seen noisy volume pots.
These were 470k not 100k I changed them anyway and the 100k resistors in r17-8 I’d say it’s the same still unfortunatelyI was thinking also R31/32 (100K) could be contributing to noise. The last thing is. the volume pot itself, not sure how, but I've seen noisy volume pots.
Replaced the zener no change unfortunatelyIf you have a couple of zeners to get 35 volts plus or minus a volt or two it is worth a shot. The EQ board only comes into play for the phono input, which I would expect a little noise out of. I don't think you need to re-flow the FET's.
I have done a complete restore on my 771 and used KSC1845s and have the hissHi sansui experts, I recently purchased a mint 771 receiver that wasn’t working, after a recap and replacing all the 2sa726/2sc1313 transistors and zener diodes it’s working very sell however I do notice quiet loud hiss on without music playing I am wondering if the transistor substitute chosen are causing this issue?
I used ksc1815 in place of 2sc1313 on the tone board note gain was approx 211 instead 560 of originals - should I replace these with ksc1845 instead given the higher hfe available?
I used ksc1845 on the equaliser board in place of 2sc1313 approx 430 gain vs 560
Any thoughts or recommendations here would be appreciated Thankyou
I have done a complete restore on my 771 and used KSC1845s and have the hiss. Madening!
Yes have a look here. The gain of the power amplifier in the 771 is very high, @Leestereo performs a mod to reduce the gain of the power amp section to reduce the hiss.I think Leestereo did a whole 771 upgrade thread where he addressed the hiss issue on these?
Thank you! It’s like striking gold!I think Leestereo did a whole 771 upgrade thread where he addressed the hiss issue on these?
Thank you so much!Yes have a look here. The gain of the power amplifier in the 771 is very high, @Leestereo performs a mod to reduce the gain of the power amp section to reduce the hiss.
Part 2: Constant Background Hiss & Hum
With the volume control at minimum, a constant low-level hum and hiss noise in both channels was heard over speakers or headphones; noise is much more intrusive when using headphones. During loud playback levels, the noise is apparent during the "silence" between music tracks, and is independent of input source. Unlike the the "popping" noise/fluctuating DC offset issue, this noise issue was affected by the preamp controls, e.g., the -20dB muting switch makes the noise virtually inaudible with the volume at minimum. This behavior suggests...
