Well well well… where to hide a sansui 800 from my wife ?
The 800 does so much with so little! That said, I developed a fixation on the Eight years ago and wonder if you folks could share some insights on it--it was said to be an engineer's receiver, with no corners cut, down to the anodized aluminum heat sinks. I recall someone saying it had even more low end grunt than a 9090DB; which is high praise indeed.I agree - there is no way the 800 in specs nor in build is in the same league. Its hard to beat a X17/9 series or the build of an Eight with individual resistors for tone controls. And there might be a bit of a surprise element too. I am focused on the sonics - and to even go there you have to like that early SS cap coupled sound that it shares with the 555's,777's, 2000's etc.etc. It has impressed me enough to undertake a full restore, which I should have a write up with pics this coming week. I am keenly aware of the limitations of these designs - distortion, channel separation, inherent noise, yet - some of those early designs, the 777a in particular - to me is sonically superior to some of the later amps, as long as you can accept some deficits on the power and distortion levels.
I had a restored Eight (caps and transistors) It's a very nice amplifier, but as others have mentioned difficult to work on, although the 800 have given me more headaches than the Eight ever did - more on that later when I do a write up.
I find it very detailed, punchy, great separation, but a tad dry or lean in the mid section - which to others might mean, more correct. I Also have an Eight deluxe that although original, does seem to be a bit more musical and "fast" than the Eight. Regardless its an impressive amplifier section as a real engineers receiver because no cost cutting: Gorgeous anodized heat sinks, triple tone controls with individual resistors instead of carbon pots, plug-in driver boards and elaborate shielding, 8000 uf supply cans stock, adjustment for even current through the differential pair (you'll find 4 trimmers on each driver boards)
When I had the Eight, I'd still prefer my restored 777a (caps and signal transistors) for its even more detailed and spatial sound stage, with a deeper bottom - but again its personal preference - the Eight is a very impressive unit and should be owned for both its sound and collectability, it is a true statement to the best of Sansui, to no compromise and to a generation of vintage where building the finest really mattered.
Remember some speakers actually require large damping factors, my drivers in my subs must have an amplifier with a large damping factor or they simply do not perform, matching the right amp with the right speaker is as important as choosing your "preferred" setup.Yes, higher damping factor keeps the woofers in an iron grip for tighter controlled bass, low damping factor let's the woofer swing more freely = less damping, which often translates to a "looser" bass which can sound like more of it.
2.34 times better; that's funny. I would call low end grunt deep, punchy bass. Why difficult to work on? 10 gallons of parts packed into a five gallon space?The Eight is difficult to work on. It is very well built. It sounds 2.34 times better than the 800. I don't know what low end grunt is in the context of audio amplifiers. Do you mean exaggerated bass?
My Scott R74S receiver plays best with Paradigm speakers for some reason. There's a synergy that's absent with every other pair of speakers I've tried.Remember some speakers actually require large damping factors, my drivers in my subs must have an amplifier with a large damping factor or they simply do not perform, matching the right amp with the right speaker is as important as choosing your "preferred" setup.
This is why I use the Crown Macro-Tech on my subs as it is the only amp that can drive them properly.
Google Sansui Eight pictures, and take a look at the internals, top and bottom.
I will do that! Good idea.
Note that my preferences are for direct coupled, vs cap coupled amps.
Why, sir?
I liked it better than the other single digit, xx1 and x0x0 receivers I've owned, but sold it some years back. I only own two receivers now - the Sansui 2000X (sentimental reasons) and the Pioneer SX-1050, which to my ears is one of the better sounding receivers I've heard. Neither are in service.
Not in service?! I had a Pioneer SX-980 and I thought it was gorgeous--very well made. Gave it to my uncle because his old Kenwood gave up the ghost.
Oh, and I have a Pioneer SX-838...technically my daughter's, but she hasn't yet realized she wants it. It is pristine, fully restored and sounds absolutely great with a pair of AR6 speakers that I have. It sits in her empty bedroom - she is out on her own now - and rarely gets used. In fact, it rarely got used when she was still here..like many younger folks, she prefers the convenience of using her smartphone or laptop as a source, and headphones or small powered speaker box for output.
Gah! These kids of today! The 838 has always struck me as a very well built machine; no way it could sound bad with such a clean internal design (I realize that's not entirely logical, but it's my logic, anyway).
I have much "better" gear, but I would not feel deprived at all if I had to live with that SX-838, the AR speakers, one of my AR turntables, and the little notebook computer and Maverick DAC that sees use in my workshop. As I've gotten older, I find myself thinking more and more seriously about actually selling everything except these pieces (and maybe a CD player) as another step of simplification.
Ironically, I think about downsizing, too. I remember when I had just one system (in college) and being delighted with it.
Maybe when we sell the big house and downsize (coming soon) I'll actually do it. Along with all of my guitars, except one.
Did not know you played the guitar, spark1. Something I've wanted to learn but cannot seem to pull off. I can fake it on the drums and do okay on a keyboard.
