My Sansui 9090 (non DB) would not come out of protection mode, so I did some research on this site and from the help of past posts it wisely lead me to look at the F2436 driver circuit board. At location R30 I found a bad/open fusible resistor, so I replaced it along with 11 other resistors, 4 capacitors, and 4 transistors that were included in the kit I bought online from Vintage Stereos LLC (qrxrestore.com).
My Sansui was working again and sounding GREAT !!! I was so happy my first circuit board re-cap job was a great success. So I decided to order a complete stereo re-cap kit from the same outfit.
With the parts included in the kit I re-capped the following Circuit boards:
F2542 Accessory Switch
F2546 Power Supply
F2547 Protection
F2541 Equalizer
F2431 Power Supply
F2549 FM-AM Tuner
F2545 Filter and Muting
F2544 Tone Control
F2543 Tone Control
and upgraded Main Filter Caps to 80v 12,000uf.
I power up my beloved Sansui 9090 for the first time since the complete re-cap and I heard a hum for a split second then the fuses blew at f03 and f04 on F2546 power supply circuit board. I pulled The F2436 Driver Board and replaced the fuses and powered it up again and POW the fuses blew immediately.
Does anyone have any suggestions where I should start to look for trouble? Keep in mid this is my first recap job. I carefully pulled and replaced each cap one at a time, took pictures watched polarity on the boards, not sure where I could have gone wrong. All suggestions are more than welcome.
Please help bring my Sansui back from the grave
F2546 Power Supply
F2547 Protection
F2541 Equalizer
F2431 Power Supply
F2549 FM-AM Tuner
F2544 Tone Control
F2543 Tone Control
