cykotic
I am in the process of upgrading all of the incandescent lamps to LED. The Dial lights and Signal and Tuner lights turned out beautiful. I then upgraded the left and right Power Meter lamps to LED and now have NO lights on anywhere. I must say that changing the lamps in the Power Meters were a huge pain, so much so that I ended up removing the entire Power Meter assembly from the unit in order to access and replace the lamps with LED. During reassembly, I spliced the cut wires back togehter with solder and heat shrink, and resoldered all of the wires I had unsoldered in order to remove the assembly (I took several detailed photos before removing the assembly so all of the wires are soldered back into their correct places). I will say that my soldering skills have not improved much since 7th grade metal shop, so I feel fairly certain that my sodering is causing a short somewhere. In summary...after reassembly I switched on the 9090DB, had lights everywhere for roughly 3 seconds and then all of them went out. I presume I blew a fuse but cannot locate a blown fuse on any of the boards. What else could it be? I've heard there are fusible resistors that could be blown but have no way to identify these as I am still a novice at this stuff. Can anyone point me in the right direction to correcting this problem? I had the entire unit restored to factory specs 6 years ago by qrxrestore dot com out of Eugene, OR, but at that time, LED upgrades were not offered or I would have had them complete it. Anyway, any help will be greatlh appreciated. Here are a few before and after photos of the Power Meters and a few others as well. I am also refinishing the wood case.
If anything jumps out at you, please feel free to jump in and give me hell!
Thanks much!
~Cy
Thanks much!
~Cy
