bbpdoubleb
Member
Unread Today, 11:15 AM
sKiZo's Avatar
sKiZo sKiZo is online now
Audio Puree-ist
Without looking at the schematic, I figure that's a fuseable resistor ... those are meant to burn to protect the more sensitive bits. Light blue or gray matte finish?
That said, they're also a bit of a time bomb, as they break down with heat over time and can blow even if nothing else is wrong. It's HIGHLY recommended that ALL those be replaced.
You'll notice they're set away from the board. That's necessary as they DO get HOT in normal operation. Make sure you keep the spacing when replacing. Good idea to crimp the legs on the new ones so they can only set down so far.
Here's the discard pile from my 9001 ... all those resistors are fuseable.
The values are usually hard to read, so you WILL need a schematic to figure out what you need, unless some kind soul here has a list ...
__________________
DAILY DRIVER > Sansui QRX-9001, Latino ST120, Maverick D1+, dbx 200x2, dbx 3BX, Carver C9, Technics SH9010, Sony GT710hd, Mitsubishi DP-EC10, dbx Boombox, McIntosh XR16 w/EQ104, Bose 161, Gekko GK1114, Art DJpre II, Magnum FM Sleuth w/Dynalab FM3, Bach Media HTPC, dbx SNR-1
Reply With Quote Multi-Quote This Message Quick reply to this message
#17 Report Post
Unread Today, 01:31 PM
bbpdoubleb bbpdoubleb is online now
AK Member
Good deal, my protection board has to be got to from bottom and the bracket that holds it in is a real sob! 3 little screws that hold it in are a bear to get to without tearing completely down
sKiZo's Avatar
Audio Puree-ist
__________________
#17 Report Post
AK Member
