Thank you, John. I tried to find the connectors, but had no success. Now I am working on the F-2580 board and the F-2581, but I need to stop because I ordered some components.I used to own a AU-9900, that had all the wire connectors removed and the wires soldered to the pins as in your picture. But not the unbelievable soldering of those larger connectors, like the one next to the relay - that really is ridiculous.
AU-9900 PCB Connector blocks
I have been wrestling with a problem on my AU-9900 for a while now – namely that a previous owner had smashed up all of the smaller crimp terminals, removed and discarded the nylon connector blocks and, soldered all of them to their respective pins. See pic “F-2573-before_detail” (1) :sigh: I...audiokarma.org
It seems back then(?), or more recently there was a misguided belief that you should solder all the connectors to avoid channel drop-outs and other connection problems with these amplifiers. I went through my amplifier and put back all the connectors, however in the mean time the connectors have been discontinued and as far as I know are NLA unfortunately.
Also, the F-2580 is an old board full of jumpers and cuts on the tracks. Also, if you compare with the new board revision, the position of the capacitors does not match. Soon, I will post a picture
