richardpp
Well-Known Member
Hi,After the new caps were installed, I reassembled the amp to see if my original protection issue remained. Well good news and bad news, it clicks out of protection, then clicks again and a lovely plume of smoke comes out of a resistor on the amp driver board. I went through and tested all output transistors as well as all transistors on the driver board with the exception of the 4 that are mounted to the heatsink at the bottom of the board, and all seem to test fine. If any of you have an idea on where to go from here, that would be much appreciated.
It appears you have a capacitor fitted incorrectly on the driver board F-2583. One of the larger caps in the middle of the board is opposite polarity to that shown in your first photo.
