Hi everybody,
This is my first post hoping to get some assistance. I managed to got hold of a beautiful sansui au 11000a which worked ok but was a little bit noisy and perhaps not as crisp as I would have expected. Based on my readings on this forum, I thought I would attempt a basic restoration, and replaced all electrolytic capacitors (with same specs), the large power filter capacitors (with United Chemi-Con 10000 uF 100 VDC), the small transistors that have a metal tab with KSC3503, the VD1212 diodes replaced with two series 1n4148 and the fuses (with same specs).
When I plugged the amp for the first time after making these changes, after about 5 seconds, the F2661 board started smoking. From visual inspection, I could see that R60 was burned. I tested some of the other resistors and realized most of the 470 ohm, 68 ohm and 1k ohm were significantly off specs so I replaced all of these resistors. I also double checked the orientation of the replacement capacitors and transistors and throroughly cleaned the botton of the board (there were a number of of small solder projections although i am not sure enough to create to short circuit). Plugged it and again R60 started smoking. Reading the forum for similar issues, I realized I needed a dim bulb tester. I made one, plugged the amp. The bulb lit up a little but the resistor still started smoking.
So I know I am a rookie, I shouldn't have embarked in something I don't fuly understand etc. But I thought I could handle it having recapped another amp and speaker. Now I am stuck with a fantastic amp that is broken and I have no possibility of having it looked at by a decent professional (I live in Morocco and can't find anyone who has any expertise of hifi). So I want to try everything I can before giving up. But I need some help please...
1. why is the resistor still burning despite using a DBT?
2. what should I look at having already checked the orientation of the replacement parts? is the issue necessarily with the 2661 board or could it be elsewhere?
Please help me. I wish I could have it repaired by a competent technician but I just don't have that option unfortunately. I am attaching a picture of the 2661 board. The service manual has a schematic on p14 and can be found at http://www.amplimos.it/images/Sansui AU-9900A, AU-11000A Service.pdf
Thank you
Thank you
