mattsd
I recently got this amp from a very good friend to completely restore and upgrade where possible. This is one of my all time favorite amps, the looks and sound are amazing.
The front end is completely modular, all the boards except for the tape copy board (F-2503) can be taken out and worked on separately from the amp. Both amp boards, the power supply and the protection board can also be taken out as well. This amp is a joy to work on with this design.
Let us begin!
TONE AMP BOARD (F-2495)
This board is fairly straightforward. C01, C02, C11 and C12 are the input high pass filter caps, originals were 1uF 50v low noise caps and were upgraded with Wima 1uF film. C03, 04, 13 and 14 are for the feedback loop, originals are 47uF 10v polarized and were replaced with 47uF 16v bi-polar. C09, 10, 19 and 20 are the output high pass filter caps, originals are 4.7uF 25v bi-polar and were upgraded with Wima 4.7uF films. All the 2SA726 and 2SC1708 transistors were upgraded with KSA992 and KSC1845 transistors, with TR01 and 03, TR02 and 04, TR09 and 11, TR10 and TR12 all getting replaced with gain matched pairs.
EQ AMP BOARD (F-2501)
C01 and 02 are 1uF polyester film caps for the input high pass filter and were upgraded with polypropylene caps of the same value. C07, 08, 17 and 18 are for the feedback loop, originals were 47uF 6.3v bi-polar and were replaced with 47uF 16v bi-polar. C23 and C24 are the output high pass filter caps, originals were 3.3uF 25v bi-polar and were upgraded to Wima 3.3uF film caps. C601 and C602 are the local decoupling caps, originals were 10uF 50v and were upgraded to 47uF 50v FCs. All the 2SA726 and 2SC1313 transistors were upgraded with KSA992 and KSC1845 transistors, with TR01 and 03, TR02 and 04, TR09 and 11, TR10 and 12 all getting replaced with gain matched pairs. Also, R25 and R26 were 5.6K ohm carbon comps and were upgraded with Vishay RN60 resistors of the same value.
Edit: Need to add, I reversed the polarity of C601 and C602 by accident in the after photo, it was corrected after the photo was taken.
FLAT AMP BOARD (F-2505)
C01 and 02 are the input high pass filter caps, originals were .22uF polyester film and were upgraded to .47uF polypropylene film, the increase in capacitance was to minimize phase shift at the lower frequencies. C05 and C06 are 22uF 6.3v bi-polar caps for the feedback loop, replacements were 22uF 25v Nichicon ES. The output high pass caps are C11 and 12, originals are 10uF 25v bi-polar and were upgraded to Wima 10uF film caps. TR01-04 are 2SC1313 and TR05 and 06 are 2SA726 transistors and were upgraded with KSC1845 and KSA992 transistors, with TR01 and 03, TR02 and TR04 getting gain matched.
C13 and C14 were 1uF 50v electrolytics and were upgraded with Wima film of the same value. C17 and 18 are 4.7uF 25v electrolytics and were replaced with 4.7uF 50v Panasonic FC. TR09 and 10 were 2SA726 transistors and were upgraded with KSA992. R23 and 24 were 5.6K ohm carbon comps and were upgraded with Vishay RN60 resistors of the same value.
More to come shortly!
Let us begin!
