Sansui au-20000
Bino18
Hi can someone help with sansui au 20000 terminal connection where is this connection go the red and white from F-2511 going to what circuit.
Hi, the connector belongs to the protection LED indicator on the front panel. You'll need to know which of the LED terminals is positive and which is negative before reconnecting it.
Usually the longer LED pin is the anode connection, corresponding to the red wire. ;) - plug the connector on, if the LED doesn't light, plug the connector on the other way round simple. ;)
