SANSUI AU-20000
Not sure I plugged it back in must have come lose. I noticed when u turn that switch that has left right l and r and normal position. When I turn it to normal position the right channel not working but when it’s in the left right position it works on both channels? Should I be concerned? Thanks
when tone defeat is on then it works but not as loud as the left channel
looks like someone beat you to it and was diagnosing a fault .
do you have the history of it ?
no I just bought it so no history
Sorry started another because the first one was about power voltage, So I thought not many will reply for the current problem
thanks
yes sorry as there was an error in the 1st thread it said au- 2000 should have been au- 20000
first try every input . if no change deoxit the switches to rule them out .
I think I found the problem that tone control circuit board that's held in place by the lock in brackets when I move it the sound comes on, can that board be removed if yes how? do you just pull it out?
thanks
sorry not worked on one of those ., maybe the manual will help some ..
ok well it seems stable now so im not touching it, the only thing now is the right channel is slightly louder, is that a problem or should I just leave it,
thanks again
