No indication that TR08 shorted against HS, and it is indeed mounted to HS. Center leg, closest to HS is insulated with tubing. Indications are that NTE85 may be the best replacement for TR08. 2SC1445's came in today's mail. Bad news is I suspect they're counterfeit. The silk screen print looks good but the size differs. Also the underside has a difference in construction ie there is a 1/4 inch diameter circle stamped/crimped on the original C1444's absent on the 1445's.I am reluctant but tempted to report this activity to e-bay. Gluing the trace sounds doable. In the process of watching trace repair videos, it became clear that I have, to date, 7 damaged pads. Two of those pads are as much as 2/3 gone and 5 about 50% gone. Is it possible that point-to-point wiring is more practical than pad replacement? Still having fun but I'm nearing the apex of my ability. Lastly, would you suggest replacements for the C1444?
