HansVenlo
Member
Do I also have switch the cables from the sockets? I did not do that when I performed this test when I started the hunt.I'm sorry that you are still having problems, I just finished a restoration on my first AU-517 ( and my first restoration in general) so I don't have the experience to help you. Having said that have you tried swapping the wiring between F-2721 and F-2722, easy to do and you don't have to remove any parts. Disconnect the right channel and connect it's cables to the left channel see it you still have a hum running one channel, at least you can rule out the driver boards from your fault finding.
Today I put a few resistors in that were backordered and I will test again tomorrow.
