HansVenlo
Member
Thank you very much for helping.The DBT lighting up and the voltage drop indicates that is short in the right equalizer circuit. Can you post a picture of the F-2723 board?
I mostly followed your recommendations in restoring this amp.
must apologise for the big 470uF caps on the equalizer. I had them laying around and was not quite sure of the replacement 470 uF Bipolars I put in were the culprit, so I temporarily put these fat Nichicons in place.
What I did on this board:
- recapping all electrolytics (most of them 10uF 50V audio grades Nichicons UKT series.
- replacing the four fusistors with 82,5 Ohms Yageo 0,25 Watt 1% metal film resistors.
- replacing the VD1212's with 2xN4148 in series
I hope my pictures are good enough.
Hans
