A further bit of (important) info: pins 1, 6, and 8 on the 6BQ5 are not shown as NC (no connection, but as IC (internal connection). This should be interpreted as "never connect anything to these pins stupid!" as they could connect to any element inside or a feature like the getter or a mica support inside the tube. If they were NC, it would be OK to use as a tie point, but it's not. In actuality, some 6BQ5s and or 7189s do connect 1 and 6 the same as the 7189A. "Short" indications may or may not show on those pins in a tester; ignore them either way. The 6P14 data sheet shows these three pins as unconnected, which is my experience. For all others, assume nothing.
