I acquired a 717 with the left channel being I guess distorted, but also sounded like only partial signal. The little sound that was coming through the left channel was obviously less volume than the right. When used as only an amp, both channels work fine. I thought it might be in the preamp (F-2720) section, so I recapped that as well as replaced some transistors, diodes, and fusistors. No change. I then moved on to the power supply board F-2663. I replaced all of the electrolytics and removed the corrosive glue and everything it touched. Also on that board, some resistors, diodes, the relay, and the sc1708 transistors. No change. Recapped F-2723, as well as replaced diodes, and fusistors, no transistors yet on that one. No change.
Where I messed up was not checking voltages before I started this process. On the PS board F-2663 voltages are as follows:
pins:
24,26= -33.62
18,20= +34.42
17,19= +34.74
23,25= -.812
TR02= E +35.14
C +55.19
B +35.76
TR04= E -34.04
C -56.50
B -34.66
TR03= E -1.070
C -57.30
B -1.645
TR01= E +35.37
C +55.85
B +35.98
What's going on with those low voltages? Is it possible that TR03 is bad? Or is it something farther upstream?
I don't want to continue replacing parts until I get the problem figured out like I should have at the beginning. Thank you for any help you can give!
pins:
24,26= -33.62
18,20= +34.42
17,19= +34.74
23,25= -.812
TR02= E +35.14
C +55.19
B +35.76
TR04= E -34.04
C -56.50
B -34.66
TR03= E -1.070
C -57.30
B -1.645
TR01= E +35.37
C +55.85
B +35.98
