RR--
It's been a while since I've posted here! mostly because I've been completely satisfied enjoying my fully recapped Sansui 8080 and AU719 daily without issue.
Recently though my AU-719 has been acting strangely, usually when flicking the off switch the amp clicks, the music stops and the lights immediately power off until recently.
Now when switching the amp off it'll continue to play music for a while until the protection circuit cuts in, the lights slowly fade out as the capacitors slowly loose their charge.
Powering on the unit is the same as normal. It still works like normal and plays music beautifully.
Below is a video of it's behaviour with and without music playing.
A bit of history about this unit, I bought it fully stock and fully recapped it myself back in 2012. In around 2018 I replaced a troublesome transistor on the left and right channels causing an intermittent fault due to a corroded leg, I also replaced every other transistor of that type as well as the bias and DC offset trim pots.
The amplifier has been running daily without fault for the past 3 years.
Any idea what's wrong? I'm suspicious of the relay as it is currently a 1979 original part.
No music:
https://drive.google.com/file/d/12KxsZUTIXOsGt4KZ6cVtlkhZW3e1EkUm/view
Music:
https://drive.google.com/file/d/1DhQ9pWV3zi8ZpTXuPwKJK4hpnnIRwPiQ/view
Thanks in advance
No music:
Music:
Thanks in advance
